fyrstormer
Just kidding, I already know the answer. ;-)
I recently bought a TRX-6, and I wanted to get it up and running without spending any extra money on it, so I swapped the stock motor (which I plan to sell) for a TrailMaster Sport 550 21T that I had in one of my many spare-parts boxes. I have my TRX-6 geared pretty high, 20/39, same as my TRX-4, so I can run it on 2S and still get 14mph in second gear. (or at least, the TRX-4 can go that fast -- not sure about the TRX-6 yet.) I took it out for a drive tonight -- nothing serious, just up and down some curbs and through some grass and over a drainage trench filled with canteloupe-sized rocks, plus a couple "speed runs" to see how the TRX-6 handled on flat ground. I ran the battery down from full-charge to storage-charge, so...about 65-70% of the total charge, I guess?...and when I got back to my house I noticed that distinctive smell of overheated wiring.
I expected the motor to be hot, but I didn't expect it to be over 200°F. The ESC's heatsink was about 130°F and the battery was barely warm to the touch, so obviously the motor is the weak link in my current setup. I expected that, just not to such an extreme. Interestingly, the armature coils still look nice and shiny -- all of the smell was coming from the commutator, which is currently regretting the day it was born. The comm is covered with a lovely shimmery-black coating of baked-on carbon dust from the brushes.
So yeah, if anyone was wondering whether a TrailMaster Sport 550 21T is up to the task of moving a 9-pound TRX-6, the answer is "no". (at least, not on 2S.) Now I get to contemplate whether to buy yet another TorqueMaster Pro to put in my TRX-6 just like all my other crawlers...or maybe try a 5-pole CrawlMaster Pro since I'm running a pretty high-torque/low-rpm setup and 5-pole motors are supposed to be better for that...or maybe splurge on a HobbyWing Axe, which I'm also curious about. I'm a little concerned that any 550-size brushed motor will be overwhelmed, but I'm also a little concerned that if I put a brushless setup in my TRX-6 then I'll suddenly want to spend a couple thousand dollars putting them in all my other crawlers too. Choices, choices.
In any event, the moral of the story is: If you're going to run a motor in a high-torque/low-rpm setup, make sure it's a premium motor with the strongest magnets you can get, not a disposable motor with cheap magnets. If the armature doesn't have strong-enough magnets to push against, it will behave like an electric heater instead of an electric motor. I already knew this, but somehow I was still surprised by the result of this test.
