Panther6834
FACTOID: Group of goats is called a "tribe".
A long time ago, in a galaxy far, far away, there was a White Goat...an Imperial Goat. Ok, so it wasn't really all that long ago, and it wasn't "far, far away". It was right here, on planet Earth, in the SF Bay Area. However, that lil goat gave its owner a bug...a 'buggy bug', that is. Before his Stormtroopers had even "hopped aboard" their droid-searching vehicle, this Black Cat was already planning a sequel. Before that Imperial Capra even had its maiden voyage, I had already acquired some of the necessary spare parts while scouring the junkyards of Tatooine & Jakku. Moving forward four months, enough of the puzzle was figured out, that "surgery" on this whatchamacallit could finally begin.
If the name isn't enough of a giveaway, this phat Capra is a 'bastard'...no, not like Mike Myers' "Fat Bastard" (if you don't know, look it up)...we're taking the "illegitimate child" type of 'bastard'. Similar to my first Rustler 4x4 project (Rusty-Frankie), CAPbRAstard is made up of parts intended for multiple vehicles. In 'honor' of that first "kit-bashing" project, I will even incorporate some Traxxas parts into this build. I figure, if I can figure out a way to stuff a couple of Stormtroopers inside of one Capra, I can figure out a way to use Traxxas parts in another Capra.
This will be my first time completely building a vehicle from parts. Yes, I've taken a Traxxas Rustler 4x4, and 'converted' it into a "true" stadium truck; yes, I'm in the process of taking a Traxxas Rustler 4x4 pre-roller, and converting it into a track-ready, competition-capable 1/8, eBuggy...but, this will be my first time starting with nothing but a pile (actually, more like several boxes) of parts, and turning them into a complete vehicle.
Ok...enough jibber-jabber...with that said, let the games begin..........
I know many reading this have probably done this many times...and, for those of you who've done build threads on your creations, I thank you, as it's your builds that have inspired me to try my hand at it. Unlike Axial's Capra, mine will have 4-wheel steering, and an AX10-style 3-gear transmission.
Pre-production of CAPbRAstard began in late-January, with nothing more than assembling the cage. I wasn't 100% certain if need to modify the cage-frame for my intended 4WS, but I had a feeling I'd need to...and, I was correct. The rear servo easily hit the lower-rear part of the cage...so, out came my trusty Dremel, to remove some plastic from the rear end (to make room for the rear steering servo. Since my plan was to not use the Capra's stock fuel cell, i wasn't worried. After a little cutting here, and a little grinding there, you'd never have known anything was removed (except for the sanding that would still need to be done).
After finally receiving the Vanquish servo mounts for the Currie F9 SCX10.2 axles (which included upper links), I installed the servo mounts to the (empty, as I have yet ordered the gears, or steering knuckles) axles, as well as the (longer-than-Capra) upper links, for a quick test-fit. I could see there'd be no further problem of the rear servo hitting anything...but the front was close. Thankfully, the front still cleared, with enough room for the horn.
Initially, I had planned on including the Vanquish Hurtz V2 3-position dig...but, in test-fitting the transmission, I discovered that the dig servo bracket extended past the skid, into the area occupied by the fuel cell. In other words, it ain't gonna fit...so much for that idea....out went the dig.
Thus ended the first day. I would have liked to have gotten more of the build completed, but was unable to do so, I'm still awaiting parts.
~ More peace, love, laughter & kindness would make the world a MUCH better place [emoji1690]
