pyranahryder
hi i am planning on building berg v1 axle,and my first question is on c-hub and knuckle i see differente way that people goes but want to have more clear opinion the set-up i have see at the moment are
-axial c-hub with bully knuckle
-xr-wraith c-hub and knuckle
-vp 8* c-hub and knuckle
-vp non 8* c-hub and knuckle
-dlux knuckle
and here at my home i have some axial scx10 aluminium c-hub with knuckle(steering arm seem to be longer than habitualy) don,t know the part number of it
-i plan to milling the gear case and tube
-drill the gear
-i would like to know the difference between stock 2sd and 3th gear compare to manoaman ones(and does it possible to find them at this time)
-i have rcbros locker in
for front axle what is the best low cost way to have something strong i have thinking about dlux ofna style or modded wraith but plus for modded wraith
for the rear i will maybe go with dlux but dont know if i will use is kind of ofna hub it is something i woul try
so all comment will be welcome and pics of what you have or suggest wil be apreciated
for the part i know dlux and rcbros do some but if it have other people than done one let me know too
thanks to all i am newbie with moa
-dlux knuckle
-drill the gear
