I am on 6 months with the cheaper 20KG version and have run nothing smaller than 4.75" tires, about half of that time has been 5.2" boggers. It's a little noisy, but fast. The rig it is in now is 8lbs ish so we'll see how it does but so far for the price I've been satisfied with it. I get the 'buy once/cry once' thing though, I may just be lucky with this one. But hard to argue against it if it's lasting that long for $15. I bought one of the heavier duty ones to replace the RTR servo in my 10ii but haven't had to swap it yet.
It wonder where those cheap amazon servos are made? I know Amazon doesn't make them. I wonder how similar they are to a Savox or other higher dollar one?
If I had to guess, China. They are branded under Zoskay, Annimos, and several others. Here are the specs on the 20KG version:
Features:
- High-precision metal gears with hard anodizing
- CNC aluminium middle Shell,
- water proof rubber seals screws
Sepcification:
Brand: DSSERVO
Item: DS3218MG
Stall Torque (5V): 19 kg/cm (263.8oz/in)
Stall Torque (6.8V): 21.5 kg/cm (298.5 oz/in)
Dead band: 3μs
Speed : 0.16 sec/60°(5V) / 0.14 sec/60°(6.8V)
Operating Voltage: 4.8 ~ 6.8 DC Volts
Weight: 60 g (2.12 oz)
Motor Type: DC Motor
Gear Type: Copper & Aluminum
Working frequence: 1520μs / 333hz
CE Certification: Yes
Size: 40 x 20 x 40.5 mm ( 1.58 x 0.79 x 1.60 in)
EDIT: they aren't "Amazon" servos, they are also sold on Banggood, NewEgg, and a ton of other places. Also labeled Goolsky and other names I can't pronounce. I'm busy with work right now so not a lot of time to dig but if you are industrious just follow the DSServo paper trail.
They've been discussed ad nauseum on the http://www.rccrawler.com/forum/electronics/578969-what-newest-cheap-servo-hotness.html thread, goin' WAY back (That thread is 54 pages! Ought to be stickied, IMHO) - the brand, if there is one is technically DS Servos. They are distributed by countless Chinese companies, and pop up everywhere you look, at insanely low prices if you buy a bunch at once. They really ought to be installed in EVERY RTR crawler/trail rig as they are much better than what those come with - but of course they do have their limitations.
As long as the rig is not really heavy, or running really large diameter tires, and your steering endpoints are set correctly, the DS3218 and the Pro version will last quite a while - my brassed-out Ascender has been going for years on one.
I have a DS3218 Pro in my nearly stock Enduro and I'm testing a DS3225 (same, but 25kg) in my nearly stock TRX-4 Defender, and I have a DS3235 (35kg) that I'm going to throw in a modded and faster-running, taller-tired Enduro (going for more of a hillclimber/mild rock bouncer) next.
I do use a Holmes Hobbies SHV500 v1 in my Bomber - I also had tried a ProModeler 470oz-in in it, but it is going in my 2nd Bomber that's not completed yet.
EDIT: Shoot! I forgot, I just picked up a v3 SHV500 as well, it's going in somethin', I forget what... "thumbsup"
