in search of 5mm rear scx10 axles
snowbikebear
dallas
i have vanquish vvd that have 5 mm axle nut shafts . i am looking for rear axle shafts that are 5mm to match the front . i dont want 5 mm front and 4mm rear due to ocd . stock axle shafts are 4mm . looking for help . i have three sets of vvd so i will need three sets of rear axles. any help would be great . i cant believe vanquish makes 5 mm front but not a rear.
I could be wrong but I thought I saw (I'm not searching 19 pages, you can do that) that Creeper Bob will do a HD titanium axle (5mm) on request.
http://www.rccrawler.com/forum/axles-trannys-t-case/397855-cbrb-custom-titanium-axle-shafts-19.html
Titanium is not a good material for axle shafts...good quality steel is what you want.
Or you could buy the 4mm stubs from VP and run those instead of the 5mm in front. That's what I did when I got tired of 2 different sized wheel nuts on my rig and realized that there was no need for the 5mm stub.
Vanquish Products SCX10 VVD Rebuild Kit
Yuppers. "thumbsup"
:twisted:
Or ....
5mm Scale front hubs:
Ultra Hubs - Front M5
And 4mm Scale rear hubs:
Ultra Hubs - Rear M4
That way you can easily tell them apart ... and everything looks awesome.
"thumbsup"
Good hardened steel is in fact stronger then titanium. I see a lot of guys on here that think titanium is indestructible and the strongest metal available. The appeal of titanium is the strength to weight ratio. Its just a hair heavier the billet aluminum but much stronger. When it comes to 5mm axle shafts either one should be plenty strong. Maybe with a heavy rig, oversized 2.2 tires, big power and a mean trigger finger they could break but under normal driving they will both be great.
Sent from my ALCATEL ONE TOUCH Fierce using Tapatalk
