Hi guys, I have a mst cfx-w and I want to change the plastic shock absorbers as standard for aluminum ones. My doubt is in the ideal size for these, since very long ones will lift the center of gravity quite a bit, but I want some that have a longer distance than the original 70mm. I have thought about installing about 80 or 90 mm, what do you recommend? If someone already did what is the performance? Thanks in advance and greetings .... 8)
