Hi all. Pretty new to the crawling scene. I just recently completed the SCX10 ii kit and was out crawling on a pile of wood and all of a sudden it was acting like it was browning out. Then it just went berserk. I managed to get the body off and noticed smoke coming from the motor and the esc was extremely hot. I am using the AE5 esc, Axial 27t motor with a Tactic TSX57 servo and powered by a Kinexsis 3S 5100mah Lipo. Not sure what happened but it has only been about 2 hours of run time. I ended up putting the AX10 trans in it in place of the stock trans because it was ungodly loud and had really bad chassis roll. Thought maybe changing to a smaller trans would help and it helped some but there is still quite a bit of chassis roll almost like there is something binding. But I checked gear mesh (all good), trans is smooth when not connected to the axles and axles are smooth also. Can't figure it out. Might have I just got a bad motor and esc? I'm at a loss. I have the 2017 CRC JK RTR and it is buttery smooth and very quiet. Think maybe I put something together wrong or something I need to check? Appreciate any words of wisdom.
