Steve118
I'm currently building a full size 4x4 replica of a Willys MB, not an actual one but fibreglass copy.
Anyway in between and after seeing all the scale MAN military 6x6 and 8x8 decided to have a go myself!
First thing was a base model and decided on the Wheely King as one came along quite cheap.
Having bought up a load of spares I thought it was about time to get cracking.
So, after buying another second hand axle and a 4x4 conversion kit and some other bits and bobs I've ended up with this:
I used the standard chassis as a pattern and made two new motor mounts that I can also hang the front bones off:
Got some 6mm bar, some m4x20 grub screws and a bit of drilling and tapping later:
I used the standard crawler bones off the donor and constructed the new top bones to the right length.
Got hold of some U section ali for the chassis and after a bit of tweaking for the width bolted the motor mount on:
I had to move the chassis rails a bit closer together so the front shocks would sit nice:
Now with the long 66mm props I'm going to end up with a 18" wheelbase.
This would make the truck about 30" long. Thing is I would like to push the rear axle setup another couple inches back so is there anyway of extending the prop shaft?
As I came to this page the ad box top right had a picture of a double length like inner bit?
And for now, just for reference:
Thanks,
Steve
Thanks,
Steve
