how to set up a spektrum DX3.0
Azcats1
Tucson
I just bought a Spektrum DX3.0 with no manual and I'm having a heck of a time to set up the setting for my AX-10.. I hooked everything up to the receiver and now she goes in reverse..I can't get it to go forward..Can anyone please help me on what setting my radio needs to be at..
What ESC are you using? Did you recalibrate it? Make sure the throttle trims are set at 0, then recalibrate it with the ESC.
If the ESC is programmable, and if you can, set everything back to the default settings, do the same with the radio. Make sure that the ESC is set to forward and reversing, then with the rest of the ESC and radio setting back to the defaults, recalibrate the radio to the ESC. If it still doesn't work right, start changing one thing at a time.
The first thing I would try if it doesn't work after recalibrating it, is to set the throttle EPA to 125 for both forward and reverse, then recalibrate it.
I had trouble getting my DX3 set up right also, so I know what a pain it is. Good luck.
PS. Did you ever have this setup working? That would give us an idea if it's a radio/ESC problem, or a ESC/motor problem.
