honcho to dingo help
slashinbashin
Canton, MI
i am trying to convert my honcho to a D90 which has a wheelbase similar to the dingo. So, what do i need to convert it to a dingo wheelbase?
I am looking to make it topless and have full roof rack
If you use the links for a dingo it will be a little long since the d90 is shorter. You could modify the dingo links but it would probly be cheaper to build your own. Here is a thread with alot of good info on building links.
http://www.rccrawler.com/forum/tools-procedures/349599-how-make-your-own-links.html
I would check the driveshaft angles when the wheelbase is that short to make sure there is no binding. Hope this helps.
