RockDrifter
So to follow up the title of my post.
I've had my Kit build Wraith for a few months now and i havent had a R/C give me so much fun. The pay to play rule applies in every aspect of this hobby but the Wraith is the best all around kit i have ever built!
Specs
Kit build
7954
Mamba Max Pro
Tekin Pro4 3300kv
32p 14/62
Gear Science lube
Chaotic Crawlers Titanium Links Ups n' Lows
VP Tie and Drag
DNA beads
rtr lights
Losi crawler shocks w/ golds
20w Front 35w Rear
4pl
RC4WD MT TTC's
Had 4WS and im not HOT on it. But i have it.
Deceased Electronics
Tamiya silver can 27t
Integy 35t
Integy V11 35t
Epic 27t
7954 sh
FXR cap
all of these electronics crapped out before anything broke on the Wraith!!
Specs
Kit build
7954
Mamba Max Pro
Tekin Pro4 3300kv
32p 14/62
Gear Science lube
VP Tie and Drag
DNA beads
rtr lights
20w Front 35w Rear
4pl
RC4WD MT TTC's
Integy 35t
Integy V11 35t
Epic 27t
7954 sh
FXR cap
New to the BL setup with a crawler/rock racer. But this setup is down right snappy. Gobs of torque. GOBS. Top end is almost too fast for how topple happy this rig is but its very manageable. The Drag brake is OUTTA control!
LOL i thought to myself Castles option for Crawler Drag Brake at 213% would definitely be toooo much. So i set it at 100%. HA! way to much! let go of the throttle and BAM its on its lid.
W/O the Castle Link or the Field programmer you can only manually set the MMP to 40% Drag Brake. I have ran it 2 packs this way and its a blast for bashing. Not so hot on Crawling.
Im gonna set it to 75% and give that a go. I want the Creeeeeep but not a full lock unless i use the brakes.
to jump around a bit. I run this rig FAT. RTR weight is well over 7lbs. Haven't taken the time to put it on the scale. Very different from my Full Carbon Chaotic Special XR, coming in at 5lbs even stevens. funny how 2 lbs changes things.
I like like rig heavy. makes it VERY stable. Most of my Driving is KoH style and i have become a fan of having this rig slammed. low and wide has been on my side with this truck.
No after market parts used to get it low. Just flipped the rear towers and use soft n supple Losi Suspension components.
I really need some sway bars with the speeds this pig can get up to now. Gonna get some carbon shapes going and find some stiff metal stock to thread through the frame. If all else fails on the adventure ill just run some link stabilizers TXT style.
Some things that need attention due to the BL swap.
Drive lines! MIP's!
Trans gears.... HR all metal? loud?
RR idler
SuperShafty top shaft
RR one piece output gear.
maybe VP casings. but are theses needed?
lockers and HD gears? Im at a loss here. I know of highland crawlers pinch stlye lockers from RPP but are there any others i should look at?
Ring and Pinion gears? Axial? RRP? dont know.... never did the AX10 gig.
OOOO dinners done! more to come... need pics of stuff?? ask. i have them lol.
let me know what you think guys! need some upgrade inputs."thumbsup"
