heyok
This is an overview of the electronic items that I make with links to the threads about them.
Most items I make are built to resist water. Usually, the entire electronic package is covered in Plasti Dip and then wrapped in heat shrink.
Have a product idea or need some custom electronics work? Send me a PM.
You can order from the web store or you can send me a PM.
HeyOK Performance Web Store
Not every item that I make is listed. If you don't see what you want, please send me a PM.
Newest product:
Automatic Light Switch
http://www.rccrawler.com/forum/vendors-electronics/618627-automatic-light-switch.html#post6025746
http://www.rccrawler.com/forum/vend...ht-bar-strobes-brake-reverse.html#post6000782
http://www.rccrawler.com/forum/vendors-electronics/612968-remote-control-relay.html#post5975251
http://www.rccrawler.com/forum/vend...wo-position-servo-controller.html#post5884169
http://www.rccrawler.com/forum/vend...0-jst-plug-power-distributor.html#post5881168
http://www.rccrawler.com/forum/vend...winch-diff-locker-controller.html#post5830100
http://www.rccrawler.com/forum/vend...-winch-dual-light-controller.html#post5811005
http://www.rccrawler.com/forum/vend...lt-lighting-powered-3s-packs.html#post5575896
http://www.rccrawler.com/forum/vendors-electronics/564854-rc-switch-lipo-cutoff.html#post5510701
http://www.rccrawler.com/forum/vendors-electronics/550833-heyok-rock-lights-budget.html
Part No. RL4S
An almost plug and play winch system
http://www.rccrawler.com/forum/vendors-electronics/550764-ready-winch.html#post5343502
http://www.rccrawler.com/forum/vendors-electronics/550740-backfire-exhaust.html#post5343353
Part No. BF2
Easily add a three position servo channel to your project.
http://www.rccrawler.com/forum/vendors-electronics/543241-add-channel.html#post5284065
Servo Winch - Complete with Controller
Winch Controllers
Wireless winch controllers. Tough controllers made to run servo winches without using up a transmitter channel.
Read more here: http://www.rccrawler.com/forum/vendors-electronics/537391-wireless-winch-controller.html#post5238066
http://www.rccrawler.com/forum/vend...al-wireless-winch-controller.html#post5788704
Variable Speed! This will let your linear channel control the speed of your winch.
Read more here: http://www.rccrawler.com/forum/vend...iable-speed-winch-controller.html#post4938691
SOFT START! This will help save wear and tear on the winch line and drive train.
Read more here: http://www.rccrawler.com/forum/vendors-electronics/500705-soft-start-winch-controller.html
Winch Controller for Radio with Three Position Channel
Part No. 3PW and 3PWJST
Winch Controller for Radio with 2 Position Third Channel
Part No. 2PW and 2PWJST
Relay Driven - External Power - Winch Controller
Part No. 3PWR4 and 3PWR4H
http://www.rccrawler.com/forum/vendors-electronics/527452-compact-4-amp-winch-controller.html
Compact version of the 4 amp Relay Driven - External Power - Winch Controller
Part No. 3PWR4C
Part No. WWC and WWCJST
Winch set up tips.:
Winch controller setup - YouTube
Dig Controllers
This circuit is used to give you front and rear dig on your Motor Over Axle crawler.
MOA Dig Controller for Three Position Channel
Part No. DIG3
MOA Dig Controller for Two Position Channel
Part No. DIG2
Light Switching
THE Lighting Controller
Probably everything you need in one package!
http://www.rccrawler.com/forum/vendors-electronics/457265-lighting-controller.html#post4435415
Part No. TLC
Remote Switch For LED Lighting
Part No. RCSW1
Dual RC Switch for LED lighting
Part No. RCSW2
http://www.rccrawler.com/forum/vendors-electronics/517539-hazard-light-flasher-light-flasher.html
Part No. RCSW1F
http://www.rccrawler.com/forum/vend...control-using-external-power.html#post3339137
Part No. RCSW1EXT
Part No. RCSW1EXTLVC
http://www.rccrawler.com/forum/vend...ote-switch-leds-dim-function.html#post4286858
Part No. RCSWD
http://www.rccrawler.com/forum/vend...-dim-external-powered-output.html#post4622679
Part No: RCSW2DPD
http://www.rccrawler.com/forum/vendors-electronics/459864-two-position-channel-park-headlight-controller.html#post4459770
Part number: 2PPKHL
http://www.rccrawler.com/forum/vendors-electronics/459865-two-position-channel-dual-power-park-headlight-controller.html#post4459771
Part number: 2PPKHLEXT
http://www.rccrawler.com/forum/vend...rk-lights-head-lights-switch.html#post3805084
Part No. PKHL
(3 position)http://www.rccrawler.com/forum/vend...ght-driving-light-controller.html#post4235150
Part No. RCSW2XPAB
Brake and Signal Light Controllers
http://www.rccrawler.com/forum/vendors-electronics/401254-just-brakes-brake-light-output-only.html
Part No. BK
Brake, Reverse and Driving Light controller - lets you have working brake and reverse lights. There is also an output to turn on your driving lights when going forward.
Brake, Reverse and Driving Light Controller
Part No. BKFWRV
http://www.rccrawler.com/forum/vendors-electronics/379190-3rd-brake-light-controller-more.html#post3692617
Part No. BK3FWRV
Auto Hazard Lights with Brake, Reverse, Driving Light Controller
Part No. BKFWRVH
http://www.rccrawler.com/forum/vend...6-brake-reverse-driving-hazard-rc-switch.html
Part No. BKFWRVHSW
Brake Light Controller with Head Light Output
Part No. BKHL
http://www.rccrawler.com/forum/vend...1-koh-brake-light-controller.html#post4255354
Part No. KOHBK
Turn Signal Controller
http://www.rccrawler.com/forum/vendors-electronics/356226-turn-signal-controller.html
Part No. TSC
4WS - Four Wheel Steering Controller
http://www.rccrawler.com/forum/vend...-4-wheel-steering-controller.html#post3931858
Part No. 4WS
4 Wheel Steering Controller - controlled by a two position third channel
Part No. 4WS2P
No Brainer BEC
Easy plug and play upgrade for your BEC needs.
No Brainer BEC
Part No. NBRADJ
TWO position channel to a THREE position channel
http://www.rccrawler.com/forum/vend...-position-channel-three-position-channel.html
Part No. 2P3P
Toggle Switch Servo Positioner
http://www.rccrawler.com/forum/vend...ggle-switch-servo-positioner.html#post5245955
Part No. TGSP2
Servo Toggle Switch
Have a three channel receiver but need to control four things?
http://www.rccrawler.com/forum/vendors-electronics/469172-servo-toggle-switch.html#post4545728
Part No. SVTG
Power Distribution
Some problem solvers to make your wiring easier.
http://www.rccrawler.com/forum/vend...3-receiver-power-distributor.html#post5163084
Part No. RPD5
http://www.rccrawler.com/forum/vendors-electronics/587430-accessory-power-tap-toggle-switch.html
"thumbsup" Helpful Tips
http://www.rccrawler.com/forum/electronics/421321-another-servo-winch-building-tutorial.html
http://www.rccrawler.com/forum/electronics/422460-how-wire-leds.html
http://www.rccrawler.com/forum/electronics/442620-waterproofing-receiver.html
http://www.rccrawler.com/forum/electronics/564149-diy-manual-winch-controller-brake.html#post5505274
http://www.rccrawler.com/forum/elec...ther-one-bec-hv-servo-wiring.html#post5163234
Newest product:
Part No. RL4S
Part No. BF2
Winch Controllers
Part No. 3PWR4C
Winch set up tips.:
Dig Controllers
Part No. DIG3
Part No. DIG2
Light Switching
Part No. TLC
Part No. RCSW1
Part No. RCSW2
Part No. RCSW1F
Part No. RCSW1EXT
Part No. RCSWD
Part No: RCSW2DPD
Part number: 2PPKHL
Part No. PKHL
Part No. RCSW2XPAB
Part No. BK
Part No. BKFWRV
Part No. BK3FWRV
Part No. BKFWRVH
Part No. BKFWRVHSW
Part No. BKHL
Part No. KOHBK
Part No. TSC
Part No. 4WS
Part No. 4WS2P
No Brainer BEC
No Brainer BEC
Part No. NBRADJ
Part No. 2P3P
Part No. TGSP2
Servo Toggle Switch
Part No. SVTG
Power Distribution
Part No. RPD5
