marcod13
So, being a huge BTTF fan I just had to try and make Marty's 'suped up HiLux on the Tamiya High Lift chassis. I know that Marty's is the 1985 Toyota HiLux but I still felt that using the earlier version of the HiLux would achieve the same feel.
I started the build process with a brand new Tamiya 58397 kit. I did have to go through some suspension modifications in order to allow the body to sit properly (lower, MUCH lower). Many of these modifications can be found on Tamiya Club.
Aside from the modifications, i did not really swap any of the kit standard parts for upgrades. The only thing i changed was the motor, with a 35T Novak Terra Claw i had. The springs, shocks are all stock and dont think i need to change them anytime soon. I may opt for some RC4WD shocks and springs later, but the way it comes is great for light trail running.
It is still a bit of a WIP, i need to finish applying the side-view mirrors, rubber trimming, and the LED harness. I may also attempt to re-position the motor, transmission and battery at some point to achieve an improved scale look.
Non-Kit Parts Used:
- Novak 35T Terra Claw motor
- Novak Eiger ESC
- Traxxas 2070 servo (transmission)
- Kyosho Perfex MG Servo (steering)
- FlySky Receiver
- FlySky 6 CH "stick" type radio
- Venom 4000 mah 7.4v LiPo Battery
- RC4WD Yota Axle Hubs
- Mud Country styled tires
- 94 US Wheel styled rims
- Tubular front bumper from Tamiya Bruiser Kit
Will continue to update as I go along with the build.
Next on the list is to paint those KC lights!
Thanks
Non-Kit Parts Used:
- Novak Eiger ESC
- FlySky Receiver
Thanks
