I’ve been watching the RCCrawler Rally section for quite some time, and finally decided to get XV-01. Since I live in Czechia, land of enthusiastic XV-01 modders and rally racers, I’ve decided to modify the car so it can compete in rally races over here. Goal of the mod is to make it lighter, better balanced, and increase steering angle.
To achieve that, I’ve decided to get improved (carbon) version of the aluminum conversion kit mentioned here.
This kit features couple things that I like:
But it also brings couple of features that I don’t like:
At the end, the only thing that really bothers me is the missing front sway bar, but hopefully it shouldn’t be a huge problem due to the nature of the rally tracks here (frequent turns, gravel/mud, lower speeds).
This is how the chassis looks like:
Servo mounting position:
Battery mount:
The battery is mounted using velcro straps, the biggest I was able to fit is the new GensAce hardcase 3200mAh 2S LiPo (semi-hard case batteries are an easy fit, eg. Traxxas 2200mAh 2S).
Steering angle:
To achieve this steering angle, caster blocks and C parts have to be modified (cut/shaved). Unfortunately I don’t have a good picture of that.
Since all the components are now exposed to elements, I have decided to put the receiver in the Traxxas weather sealed box used on Rally/Slash (TRA7424), and coat the ESC (Turnigy Trackstar 80A Turbo Sensored Brushless) with a nano protect spray. However, that wouldn’t be enough in dirt, so I have also installed Dusty Motors shroud on it:
Receiver/radio is Traxxas TQi for now, mostly because I can’t find any other system that could do traction control and telemetry at the same time.
Most of the parts are stock (except rear sway bar and TRF dampers), but tons of upgrades are on their way (carbon reinforced steering parts, long damper stays, aluminum steering bridge, slipper clutch, Gmade XD shocks, Proline springs for those shocks, etc.). I’m planning to install the upgrades during the winter season.
This is the current body:
It features Killerbody LED controller, LED cases and set of LED lights.
In progress are Toyota GT86 Gazoo Racing, and Datsun 240z bodies.
- lower weight
- freeform layout for electronics (thus better chance to balance the chassis)
- higher stiffness
- Inability to use rear mud flaps
- Inability to mount front sway bar (or at least I haven’t yet figured out how to do it)
- Higher CG because of the servo mounting position
Battery mount:
Steering angle:
