hairba11
so I managed to pick up the top half of the model kit used by OBH for This phenomenal build
and i've finally gotten around to starting to work on it now that my set of 5 baja wheels from REC have arrived.
start with a pile of kit and a slightly disassembled scorcher
start messing with some of the kit pieces. dash and chair frames.
get a side put together with some fenders and start daydreaming.
get the other side put on and see it finally becoming a little more rigid
mock up a little scorcher under it.
i've left most of the scale details off so far. I'm thinking orange or yellow for the main body color so i don't want too many parts on to get paint on them. not going to do any opening doors since this will be a runner and i'll need the rigidity. next major step will be making a chassis. i can do a pan style, the sides will fold up and slot nicely into the heater channels while locating the stock suspension pieces. I will have to do a little inner fender clearancing for the shocks/shock towers, but the width isn't too far off now. I'll know more about that when i get the conversion to baja wheels and axles done.
started out with cutting out the inner fenders up front to clear the scorcher suspension, and had the front suspension bolted to an old scorcher chassis.
got the rear in the car and figured i'd need about 3/4" extension, so i grabbed another scorcher chassis and bolted the rear to it and lined them up on top of each other, marked and drilled holes in the fiberglass then bolted them together. Yay lazy!
after bolting i didn't have to hold them together and i finally get a chance to see it standing, or rolling.
now, about that custom floor pan i was supposed to include when i built my chassis.
a little thin sheet steel will do the trick. leftover piece from some duct work.
and a little cut and bend. some slight boat siding, and some 1/2" flanges to slot inside the heater channel on the model body.
looks damned good on the body.
inside shot
got the pan and body lined up, drilled through the pan and bolted it to the chassis
thew the seats in for giggles, looks like i'm going to have to make a sub floor to get the seats the right height. that will work to run r/x wires or power cables forward.
body off, i had to lose the rear cage. the lower mounts were broken, so i cut it off to leave the piece in the shock mount. the roll bar fits perfect against the top of the model body behind the rear seatback. I also had to remove the upper portion of the front body mount.
inside shot
