This is the 1st SCX24 that I bought because I use to have a 1:1 teal green '69 Chevy Stepside. It had the white wagon wheels on it. So the little green C10 appealed to me when I started looking at the 1/24 crawlers.
Haven't done much to it, bought some RC4WD white steel beadlocks & a set of Nitto tires. Probably not my best choice for tires but will do for now. Swapped out the servo for an Emax and that is pretty much all that has been done to it.
I didn't like the lights being on all the time and at times they would shine in my eyes when trying to maneuver. They have switches on eBay & Amazon that will let you turn lights on and off with a switch on the tx but they cost $11.95 each & I'm cheap, though I don't think my wife would agree. She claims I'm high maintenance. I had heard of using a servo board for this so I did a little research and found it wasn't that hard to do. All that was needed was a servo & some soldering skills.
I started with a SG90 servo
Took it apart and unsoldered the motor and the rheostat.
I then took a servo extension & cut the end that goes into the rx off and cut the signal wire back some as it won't be used. I then soldred the servo extension positive and negitive wires to the board where the motor was soldered on.
Next I unplugged the lights for the rx and plugged them into the servo extension making sure the polarity was correct. For now I have the extra wire along side the rx case. I plan on moving the lights to the grill where they belong so I left the servo extension long for that purpose. At least I hope it's long enough or I'll solder a new on on.
So now I can turn the lights on and off from the tx
