** Giveaway - Deuce's Wild 3.8 Foam Set - Giveaway** from Crawler Innovations
Nova's Ark
Tire&Foam Extraordinaire
Subscribed Member
C.I. Compound, Tyler, Texas
The giveaway winner will be chosen by a random number generator on Septemeber 1, 2017.
This giveaway is open to the public and you do NOT have to be a star holding member on RCCrawler.
However, Crawler Innovations highly recommends supporting the original website that birthed the RC Crawler hobby into what we have today. If you would like to support RCC, the information about becoming a star holding member is here: click this link.
Post once a day to be entered.
Deuce's Wild Single Stage for 3.8" Tires, 7.50" - 7.25" Tall Foam Pair
Part # CWR-3009
Crawler Innovations was the first to combine closed cell and open cell foam into one package with our Double Deuce and Lil’ Nova product lines. After we'd perfected those systems, we turned our attention towards the faster paced rock racer, heavy scalers, and basher genres. The Deuce's Wild Foam line was created. Using only the firm inner material, while focusing on the machined size and shape of the foam.
CWR-3009 was designed for use in the Pitbull Tires 3.8 Rock Beast Tire (PB9009ZDK) but will fit many other brands of tires as long as they are similiar in height and width. Examples are the Axial Racing BFG Krawler, Axial Racing Falken Wild Peak and the RC4WD Mud Slinger.
These foams are much firmer than anything available on the market. They do not fold over under load whether it's high speed, heavy weight, or simply turning. These foams rely on a small air gap between the foam and tire. This loose area allows for the tire to obtain traction, while the foam supports the tire.
Approximate size: 6.625" Height x 2.625" Width (Remember that foam goes inside the tire and one must subtract lug and carcass thickness, plus any reinforcing from the overall tire height.)
#ci #deuceswildfoams #rccrawler #crawlerinnovations
Size comparison to a 2.2 Standard DW:
Available @
Crawler Tires, Crawler Foams, Parts and Accessories by Crawler Innovations
Thank you for entering and good luck"thumbsup"
