The giveaway winner will be chosen by a random number generator on October 2, 2018. To enter this giveaway you must be a star holding member here on RCC. If you need information about becoming a star holding member, click this link.
Crawler Innovations is giving away one set of Deuce's Wild Single Stage 2.6" Foams for JConcepts Fling King tires.
Post one time to enter.
C.I.'s Deuce Wild Single Stage for 2.6" Fling King Tires Foam Pair
Part # CWR-3020
Crawler Innovations was the first to combine closed cell and open cell foam into one package with our Double Deuce and Lil’ Nova product lines. After we'd perfected those systems, we turned our attention towards the faster paced rock racer, heavy scalers, and basher genres. The Deuce's Wild Foam line was created. Using only the firm inner material, while focusing on the machined size and shape of the foam.
CWR-3020 is designed for use in the JConcepts brand, "Fling King", 2.6" rim Mega Truck Racing tire with the JConcepts "Dragon" 2.6" rim/wheel. These foams will fit many other brands of tires and rims, as long as they are similiar in height and width.
These foams are much firmer than anything available on the market. They do not fold over under load whether it's high speed, heavy weight, or simply turning. These foams rely on a small air gap between the foam and tire. This loose area allows for the tire to obtain traction, while the foam supports the tire.
Approximate size: 4.875" Height x 1.750" Width (Remember that foam goes inside the tire and one must subtract lug and carcass thickness, plus any reinforcing from the overall tire height.)
#activatedoutlaw #deuceswildfoams #rccrawler #crawlerinnovations
C.I. Mega Truck;
More pictures:
Available @
Crawler Tires, Crawler Foams, Parts and Accessories by Crawler Innovations
Thank you for entering and good luck"thumbsup"
Part # CWR-3020
C.I. Mega Truck;
More pictures:
Available @
