Crawler Innovations is giving away one set (4) of our 6 Bolt 2.2" Performance Wheels.
The wheels are available in the web store if you would like to order your own:
Crawler Tires, Crawler Foams, Parts and Accessories by Crawler Innovations
Use Discount Code;
iamworthy
For 11% off your order
The giveaway winner will be chosen by a random number generator on July 31st. To enter this giveaway you must be a star holding member here on RCC. If you need information about becoming a star holding member, click this link.
Thank you for entering and good luck"thumbsup".
Crawler Innovations is happy to bring another new product to the RC Crawling market. The 6 Bolt Performance Wheel is a glue on wheel with a 2.2" bead size, is 1" wide, and is designed to be used with Vanquish Products SLW hubs. The Axial Trail Ready plastic hubs also fit these wheels for the weight conscious comp crawler. 12 Stainless Steel Button Head hardware included.
The 6 Bolt 1" Performance Wheel itself is just under 14 grams.
#crawlerinnovations #activatedoutlaw #ayalametalworks #doubledeucefoams #6boltwheels
Use Discount Code;
iamworthy
![13561636505_89a035a8fc_o.jpg](/forums/proxy.php?image=https%3A%2F%2Ffarm4.staticflickr.com%2F3678%2F13561636505_89a035a8fc_o.jpg&hash=d5aaf506a134732a38c46869c26b9741)
![13561699613_88d8c94149_o.jpg](/forums/proxy.php?image=https%3A%2F%2Ffarm4.staticflickr.com%2F3735%2F13561699613_88d8c94149_o.jpg&hash=fa99e0b8defd5e933f95faa6b2af3b87)
![13561989484_758ffb4340_o.jpg](/forums/proxy.php?image=https%3A%2F%2Ffarm8.staticflickr.com%2F7110%2F13561989484_758ffb4340_o.jpg&hash=a67027c83bdfaf19414b76e78a289e8a)
Measuring to the SLW HUB / not the wheel hex surface from the back of the wheel.
The VP 225 SLW Hub is inset 12mm from the back of the wheel.
The VP 350 SLWHub is inset 9mm from the back of the wheel.
The VP 475 SLW Hub is inset 6mm from the back of the wheel.
The VP 600 SLW Hub is almost flush to the back of the wheel.
The VP 725 SLW Hub is 3mm past the back of the wheel.
The VP 850 SLW Hub is 6mm past the back of the wheel
![13561696693_dc7edb25ca.jpg](/forums/proxy.php?image=https%3A%2F%2Ffarm8.staticflickr.com%2F7103%2F13561696693_dc7edb25ca.jpg&hash=4bafa1e8260cb1968ad1afae44ae30fa)
![13561633295_52719fa856.jpg](/forums/proxy.php?image=https%3A%2F%2Ffarm8.staticflickr.com%2F7254%2F13561633295_52719fa856.jpg&hash=e1a36319ed52dc3f932b935bd0583cfa)
