Ordered a gen8 pack a while back (cheapest platform I've found to start a decent rig from) along with a proline f250 honcho cab and a vaterra bed cage. Also grabbed a bunch of brass, some amazon 1.9 beadlocks (had 8 lug center caps that I thought fit the build nicely) some 1.9 chyrax tires, traxxas mirror/wiper kit, a cheap servo and hw 1080 plus a holmes 12t crawlmaster sport 550.
Painted the body first, just acrylic and a brush, was shooting for the black plastic fleet trim and work truck white paint.
Got the body trimmed and stickered up and got to mounting
the ascender cage, added a spare using an old hacked up hyrax carcass on a cut up bruiser clone wheel, matched pretty alright.
The rear frame looked goofy under the cage so I cut it down and made a rear crossmember from some square stock and a piece of flat bar (didn't get a good progress pic of it, but will show itself later on)
Boxed it in and smoothed it out
Rails fit nicely below the vaterra cage posts, so I made a cross beam with 2 holes to locate it and put a couple magnets inside the lower cage to hold it (can be seen in later photos)
Did some trimming to the cab wall to get everything to fit snug (didn't want to do sliders at this time, for a simpler look)
Was trying to sort the front body mounts, and made a mount with some trimmed down body posts, 2 slots in the lexan bumper section, and a couple vanquish d rings i had left over.
Mounted up the mirrors (figured its a 3/4 ton truck, needs some big mirrors right?)
Sent from my SM-T290 using Tapatalk
