Gears and driveshaft questions
Dickie691986
Carlisle
Where can I get replacement gears for my Losi micro? Something other than the stock plastic. And how can I upgrade the drive shafts? Thanks.
If you are talking about axle gears the only drop in replacements are factory. If you are talking about the transmission gears there are a few threads in here showing how to upgrade to custom brass gears. There are also quite a few posts about custom metal drive shafts. Hobby plus will soon have some metal drive shafts for the CR24 that should bolt up to the Losi.
You should definitely make use of the search function in the specific losi micro crawler section because there is a wealth of information here if you look for it
Sent from my Pixel 3 XL using Tapatalk
Every time I try to use the search function it brings up just about everything and anything for all cars. It’s a bit of a pita. Maybe I’m using it wrong though. I’ll just have to take sometime and look back through everything I guess. Just figured I would make a quick post asking since I thought that’s what forums were for. I mean they used to be anyways. But thanks for the input.
Has anyone confirmed that these will work? I have a project thats been sitting for a few years since I couldnt find a set of driveshafts that would work. I thought about using the Orlando Hunter or F-150 driveshafts but have yet to dive in on it.
The shafts fit onto the outputs. I know the length is close to the trekker,and should be ok. there's a chance the CR-24 is a bit long for the McRC. I don't remember. Either way it's easier to shorten than it is to lengthen.
Didn't see your reply, try using the advanced search instead. Limit the search to the specific sub group. It works pretty well for me and it's pretty useful.
