Hi friends, I am new community,, made this thread for maintenance pruposes for my FT011.
True, it is a boat that does not require much care , But when we talk about salt water is another matter.
If you want to enjoy your FT011 long time, it is necessary that care well, disassembling everything after each output and making sure to remove all traces of salt in boat.
otherwise if you do not, your fun will last twice the boat.
Well here I leave a single vide tutorial of how to disassemble the parts to be cleaned and rinse well with fresh water.
<iframe width="560" height="315" src="https://www.youtube.com/embed/eu0hKZMamUQ" frameborder="0" allowfullscreen></iframe>
if any part is broken or damaged , here you have a list of FT011 original FeiLun Parts:
Direction:
FT011 Servo Rod
FT011Servo direction
other Replacements:
Transmitter FT011 2.4GHz RC
FT011 Display Stand
FT011 Charger
Boat Plastic Parts:
Stock FT011 Battery case
Fixed Motor FT011 2Pcs
Bottom Hull FT011
Anti-collision FT011 Prow
Upper helmet FT011
Cabin FT011 Cover
Electronics spares:
ESC + Reciver
FT011 Brushless Motor
FT011 2200mAh Battery
Cooling System spares:
FT011 Water-cooling System
FT0113Pcs Original Silicon Tube
FT011 Steel Tube Axe
Propeller FT011
FT011 Tail Rudder
Transmission FT0113Pcs
FullBoat kit
FT011 Full Boat
greetings
I hope that helps someone.
comments and other experiences very welcome
Direction:
FT011 Servo Rod
other Replacements:
FT011 Display Stand
FT011 Charger
Boat Plastic Parts:
Bottom Hull FT011
Upper helmet FT011
Cabin FT011 Cover
Electronics spares:
ESC + Reciver
Propeller FT011
FT011 Tail Rudder
FullBoat kit
FT011 Full Boat
greetings
