Front Dig/Burn
crawlercon
Kansas City
I just posted this on another forum but I just joined that one and don't know if they are basically a scale club or not. So I thought I would try over here too.
I'm pretty new to the RC world but have dived in head first and am loving it so far. I've gotten the uses for rear dig down pretty well and use it regularly but I can't really figure out where front dig aka Burn would be used.
I happen to have added rear steer to my comp crawler so technically if I want to spin around on a dime or shift the rear end over going in reverse I could use burn and full rear lock to do that, but I don't see that being needed very much and rear steer isn't even allowed in 2.2 comp crawling events plus reversing is points wasted, so what do you do with it with a no steer rear axle going forward?
If you know of any videos showing guys using it to an advantage please share links.
I didn’t know such a thing existed so I’m curious to learn as well.
Must be MOA is my guess.
Front and rear dig is always a confusion on which is which it seems. To simplify MY understanding, I refer to front dig as rear locked and rear dig as front locked. (I only mention my understanding to clarify what I am talking about, not here to argue which is correct :lmao:)
My only experience with rear steer and FR/RR "dig" is super's. For me, I could not see an advantage with rear dig, without rear steer. All its going to do is load up the suspension, and there is nowhere to move the axle but slide to the downhill side. With rear steer, there are similar to advantages to front dig, especially when the rear axle needs to clear a gate. 4 wheel steering helps but sometimes you need to lock the front or at least slow it down when youre right into the gate.
I understand you are talking 2.2, so maybe someone else can chime in but I see no use for rear dig without rear steer. Every situation the rear will slide out downhill.
I am curious to hear as well though. Always willing to learn.
Interested about knowing the link of the other scale forum you were reading.
please post it
pep
