What’s up RCC, figured I’d start documenting this build before I get too far ahead of myself. Some of you may have seen Twade984 build in the Capra section, well this is basically an imitation of that to a point. After driving the rig for a short period of time, I knew I needed to build one.
I ended up snagging a complete Capra from twade, did some wheel’n and deal’n to swap the stock axles and some $ for these lightly used clear F9 10.2 style straight axles.
The beauty of this build, is it works using all the stock links, with only swapping out some rod ends.
As of right now the build specs are as follows
Vanquish 10.2 F9’s vanquish internals except for ssd OD gears up front.
Vanquish 3 gear transmission sitting on a UCfab delrin/carbon skid
Incision driveshafts
Stock Capra links with some large
Traxxas rod ends
Dravtech silver short shocks with 5mm spacer 70wt ultra soft & soft springs
Vanquish bully 1.9’s in silver
Proline krawlers in predator with proline dual stage foams.
I’m unsure on electronics at the moment, it will be getting an shv800 servo and either a crawlmaster mini with 1800kv revolver, or castle micro x with 1900kv slate 2850kv slate or puller pro 2200kv.
Again this is a pretty straight forward build, with the slight adjustments here n there but I can’t wait to get this thing on the rocks
Traxxas rod ends
