cartronicshn
What do you guys think? wk axles with wk tranny or pede tranny, i have a 3300kv motor and esc and can go 3s on it, waiting for some panther paddles.
![12-08-10_1046.jpg](/forums/proxy.php?image=http%3A%2F%2Fi66.photobucket.com%2Falbums%2Fh252%2Fcartronicshn%2FWheely%2520king%2520tuber%2F12-08-10_1046.jpg&hash=41b4285883f68e911c138c08fcf05d86)
![12-08-10_1044.jpg](/forums/proxy.php?image=http%3A%2F%2Fi66.photobucket.com%2Falbums%2Fh252%2Fcartronicshn%2FWheely%2520king%2520tuber%2F12-08-10_1044.jpg&hash=f7cfcb9755ce797bbec75973f2d5b326)
What do you guys think? wk axles with wk tranny or pede tranny, I have a 3300kv motor and esc and can go 3s on it, waiting for some panther paddles.
Morten, thanks for the tips, the wk tranny already has the metal gears in it (learned the hard way with brushless outrunner:rorWK gearbox will need steel gears and slipper
Pede gearbox already have steel gears but a lower ratio
The bearings and diff gear in the axles also need to be upgraded to HD parts
Trust me I learned the hard way :shock:
Morten
Hey bud"thumbsup", i am still around, as you can see i am recycling the wk for this project, and thanks for the tip8)Wow, long time no see. Looks good, Yeah I'd drop the hardened in the rear, but you could get away with sintered for the front and save yourself $20
Morten, thanks for the tips, the wk tranny already has the metal gears in it (learned the hard way with brushless outrunner:ror, as for the pede tranny i have spurs in a bunch of different ratios and metal gears, only thing i am waiting for are the axle metal gears (i already have hd lockers for it) and the paddles, thanks guys for the tips"thumbsup"
I remember them being parts for the rs4 if memory serves me right. I would have to look in the wk forum.Any chance for a link to the HD gears you are putting in the axles? PUHLEEEAASE!:ror:
Morten, thanks for the info"thumbsup", couple of questions, how are the o.d. gears working for you? with that ratio do you have more top end? what tranny are you running? like i mentioned i have a couple trannies for options, i am more inclined on using the pede tranny with 70 ish spur and maybe a 23t pinion on the 3800kv motor, if not i also have a 5700 k.v. motor i pulled out of my losi d.t. since i swapped a s.c. 3800kv in it.I have the hpi overdrive steel diff gears
http://www3.towerhobbies.com/cgi-bin/wti0095p?FVPROFIL=++&FVSEARCH=86329&search=Go
These might work as well knowing that the Ax-10 and WK use the same size diff gear
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXURG2&P=Z
Morten
These are the standard E-Savage diff
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXPCZ4&P=Z
Steel WK diff
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJYM2&P=7
Morten
No hijacking here, it's tech and it's all good, i have to wait a little longer for my stuff to get here as customs in my country have been closed for the whole easter/ holly week holiday.Thanks for all the info guys! Sorry to hi jak your thread buddy.Cant wait to see it with some paddle tires shooting a rooster tail!"thumbsup"
I followed your advice and swapped the 3800 for the mamba 5700kv, and it came alive on 60 somthing spur and 20t pinion, i have put some 2.2 imex super swampers and it's starting to look good, i will have pics up tomorrow, and hopefully by the end of the week i should have the beadlocks and my paddles:roll:Can't really tell any difference in sand
but my gps said +2mph from the standard diff :shock: (on tarmac)
They are allot stronger though
I use a ´pede gearbox with a 54/18 gearing and a 3800kv, the bigger teeth last a wee bit longer than the 48p
If I had a 5700 that's what I would use "thumbsup"
Morten
Thanks and noted "thumbsup",i will try to move tranny some more but i think it's at it's limit.Looks killer. The last pic. In crawling I would have not a prob with the drive line at that much angle. Looks like a weak link is all.
Thank you for sharing your rig
Evan
