Flysky Noble transmitter questions - trim switch operation
garyk
Close
I apologize if these questions are answered here already, but I'm having trouble finding information about the Flysky Noble Tx. The manual I got from the Flysky site doesn't answer these questions either unfortunately.
Regarding the trim switches, there are four I believe: Trim 1 and 2 (above steering wheel), Trim 3 and 4 (on the grip).
Are these physically just like typical trim button where there is a center position and then left/right positions that snap back to center after releasing?
Can these be set up in the software to function as 3 position *momentary* switches? I know they can be 3 position, but I found where someone mentioned they cannot be set up as momentary. Maybe that has been added with a firmware update?
Can these be set up as incremental position (not sure if that is a good term to describe it)? I need to be able to use something like a trim switch to move a servo in each direction. Pressing once in a direction would move it 20%, second press 40%, third press 60%, fourth press 80%, fifth press 100%. Is that possible?
Thanks in advance.
