boaty3
I have a hacked GT3B, a RC4WD winch and their wired winch controller. I have it hooked to channel 4 on my receiver and set to work of the D/R switch. I have it set for momentary control. My problem is it works fine going out. Press the button forward towards front off control and winch spools out. Problem is spooling in. First off it will just start spooling in on its own. I can press the switch towards the spool out position and it stops but soon after starts spooling in again. Also, the momentary in doesn't work. If I press the switch to spool in it runs non stop until I press the switch the opposite direction towards spool out. I'm not real up on this stuff yet, but I've been though all the settings I can find and can't figure it out. Anyone have any ideas?
Thank you.
This is the controller I'm using
https://store.rc4wd.com/RC4WD-Wired-Winch-Control-Unit_p_3725.html
Thank you.
