First attept at a new bright jeep tj scaler
Creepy Krawler
Adams
Well I finially decided to squeeze the trigger and do a new bright hard bodied jeep tj. Ive picked up the body. Some proline tsl swampers, lockeduprc aluminum beadlocks, 100mm king offroad shocks, tekin fxr esc and 35t motor, and im waiting on a rc4wd 2 speed transmission and triton transfer case. Im gunna definitly take my time on this build due to heavy work hours and wanting to hit my goals on the build. So far I have the shock hoops bent, and frame cut down. Any help or ideas at any point will be welomed and appreciated. "thumbsup"
I'm trying to get pictures of my build but can't seem to figure it out. Can anyone help me out here I have photo bucket if that helps and I'm pretty sure this is what I'm suppose to use right?? :roll:
Thanks kaneohecrawler! And the build is off!!! Well since the hiccup of not being smart enough to figure out how to post pics, ive gotta a bit done to the jeep. The frames been chopped and the rear shock towers slid forward along with moving the skid plate forward a tad also to be able to put the spur gear hidden inside of the dash board, it looks pretty slick. The links are done for now to get a rolling chassis, I had to make custom ones for the lower rear links outta threaded rod, which might eventually be changed out for regular links not to sure yet.
originally I wanted to run a dinky transmission and t-case setup but can never seem to get them when there in stock so for now on this build ill work with what I have.
Dinky's stock does seem a bit erratic, tho he does have a set now in alum. But Super Shafty seems to always have them, as well as having them pre-bomb proofed.
