Finally my Bully 2 is Finished!!!+ pictures.
Meir
israel
After many months of work, until all parts arrived.
And after a lot of help from everyone.
I would like to thank jake from y town on is chassis and is patience, also to Michelle from krawler koncepts, dlux fab, and many more who helped me build the rig, and advise me.
-Bully 2 Axle
-Y town double agent chassis + links upper and down.
-Tekin T-55 Dual.
-Tekin fx'r Dual.
-Voodoo tires silver.
-crawler innovations foams comp cut 5.5.
-Big bores shocks 3.5.
- Futaba 4pls transmitter.
-Servo Hitec 7950.
-knuckle weights.
-3s lipo 850 team brood.
-CC Bec castle creations.
-Krawler koncepts skins.
The Rig weighs exactly 2020 gr, And its performance is amazing.
Sent from my LG-H815 using Tapatalk
Hope you got extra front XVD shafts sitting around. If you don't turn your end points way down and don't push the steering angle too much. I've been waiting months for RC4WD to restock. They keep saying they'll have more. I'll be buying like 5 sets if they ever make more... Nothing like having a $2k truck be completely useless because of a $20 part.
True story.
I have busted my xvd's after 2 months...
Mechanical stops are also a good idea to keep the wheels from being pushed past the end points in a bind. Very easy to do and the second you give it some throttle to pop out of the bind the axle shafts give out. Usually a pin. Then you replace the pin and the shaft breaks 10 mins later.
Sent from my SAMSUNG-SM-G920A using Tapatalk
