TITANIUM94010
How would I go about filling an ar44 Axle (SSD Diamond Pro Axle) with the transmission or diff oil?
I'm running ar44s at around 20-30 mph, and normal grease just doesn't cut it. The helical gears create a lot of friction and get very hot.
Axle in question:
I'm thinking of drilling a small hole on the top/rear of the axle similar to the ones on the Vanquish AR44 curries, then using that to fill in oil with a syringe. I'll have rubber sealed bearings all around.
Do you think I'll need to use some sort of sealant for the axle cover? I think grease should cut it, but im not sure. Suggestions?
Thanks
Axle in question:
Thanks
