Ditchrat
First let me state for the record I am not recommending this servo, or commenting on its performance. I have a simple situation that needs to be addressed. I cooked a Solar servo d772(my own fault), the promodler 470 is out of stock and so is the Solar D772. I needed something for an upcoming event, this was an option and I am trying it out.
From the manufacture.
Torque(4.8v/6.0v/7.4V): 16.0 kg-cm (222 oz/in) / 18.0 kg-cm (250 oz/in) / 20.0 kg-cm (277 oz/in) Speed(4.8v/6.0v/7.4V): 0.18 sec/60° │0.16 sec/60° │ 0.14 sec/60°
Dimensions: 40 x 20.5 x 40 mm ( 1.57 x 0.78 x 1.57 in)
Used For: 1/10 1/8 scale RC Crawler / Buggy / Truck and any application where waterproof standard servos are used
Waterproof construction keeps out the elements for worry free operation
High precision potentiometers and High-resolution digital chip, stable performance, strong anti-interference ability, fast response, high precision, control is more delicate and smooth operation.
Nothing special here, plastic covers on each end with a metal body. Body has a cast texture, maybe cast aluminum or pot metal.
So first things first, rip it open and water proof. Yes it claims it is water proof but lets find out how it looks inside.
Typical 4 Phillips screws holding it together, heads are bigger then other servos I have taken apart. Each screw had a rubber gasket.
On either end of the body is two rubber gaskets. Each one was greased as they should be. There are , however, no indents for the gaskets to seat in. It relies on simple compression from the screws, which at this point I am liking the large heads for a little more torque when tightening.
Again nothing special, a board, pot and motor. No grease no conformal coating, no water proofing. I guess they are relying on the gaskets.
Metal gears, nothing super hardened or super cheap. Maybe just cheap.
Always good to see some screws keeping the motor from twisting.
Thats about it. I filled it with dielectric, and slapped it back together. Its going in a trail built wraith, nothing super powerful nor will it be demanding. It is headed to a Recon G6 in 3 weeks, unless promodeler gets the 470 back in stock.
I did run it briefly. It is super silent, really nice gear mesh, not twitchy, centered right up and moved smoothly. I was unable to move the servo or hold it back pushing against a 1 inch horn. When I did hold the tires to bind it up, it simple bent the stock plastic steering(up grading shortly)
Overall it seems like a workable, even considering it is only running on 5v internal HW 1060 BEC. Going to install a external 6.6v tonight.
I really don't need to or want to push this to 7.4v. Its for my kid, I am just hoping it runs for 3 days straight.
Sent from my SM-G928V using Tapatalk
