Panther6834
Before I start, huge "thanks" needs to be sent to that people in particular. While several people provided advice, and some helpful insight, into "what to get" for my new C3 rig, there were two individuals who helped, and have more 1-on-1 advice than anyone else. First, special thanks to Topher (Topher Builds), who note only provided some very insightful info, but also let me to The Crawl Space, and their Game Changer 4.2 chassis, which, prior to his mentioning it, I had no clue it existed. Also, special thanks to Ikaika (The Crawl Space), not only for the excessive information he provided via email (and, that "excessive" is meant in a very positive way), but also in his assistance over the phone. Not to detract from any other small businesses, or to the quality of their customer service, but Ikaika, and The Crawl Space are outstanding where both are concerned. Just putting that out there, if anyone needs anything ranging from a chassis kit, to individual parts, to advise.
As the thread title implies, this build will be my new C3 rig, and it's built on a TCS Game Changer 4.2 chassis...but, it's not going to be a 100% new build. For sections not covered in this build thread, turn to my CAPbRAstard thread, as I'll be 'deconstructing' CAPbRAstard, and using most of it's parts to build two new vehicles. The other, to be called "CAPbRAstard Too" will be featured in a separate thread, at a future point in time. Once both vehicles are finished. The only thing remaining unused from the original vehicle should be the Capra cage, the InTheWorks skid, the interior (which came from a Carisma M10DB), the Vitavon Racing CF body panels, the one-off aluminum body "shell", and a few other minor parts. Of the most important parts, the axles, servos, and ESC & motor, will be used in the C3 rig, while the trans, shocks, and driveshafts will find their way into CAPbRAstard Too.
With no further adu...Let's Get This Party Started..........
As there is no printed "build manual" for the GC 4.2...only a collection of build videos on the TCS YouTube channel...it can, for the most part, be built in any order you want. On the 'plus' side, the build is actually quite easy, and the videos are super-simple to follow. More importantly...and, probably why Ikaika choose to do "build videos", instead of a traditional "build manual", the videos show some 'tips & tricks' that would have been much more difficult to show with a printed manual.
Many probably start with the transmission & motor mount, and a few might even go for building the chassis. I decided to start with the T-case, in-part because I haven't yet decided how I'm going to connect the front/rear driveshafts & slave shaft, and in-part because I wanted to slightly "customize" the T-case & trans housing, both of which are 3D printed. As you can see, in the photo below, the material was a medium gray when received, but now has a extra dark metallic "oil stained" look to it.
This was done in a 3-layer process, starting with flat black enamel, then topped with an aluminum lacquer, and then finished with a few coats of clear semi-gloss urethane. Honestly, I'm not sure 'why', other than I just didn't want the original gray. Some will probably think I 'ruined' the appearance, while others will think it's 'fantastic'. Personally, I like it...and, that's all that matters, right?
Building the T-case was fairly simple. The only 'difficulty' (which is a simple "trial & error" process) is determining the property shimming of the gears, and making certain you insert the idler gear in the proper direction (ALL gears in this kit are helical, so each gear fits in only one direction). Once that's complete...and, assuming that you fully seated the 1st & 3rd gears into the pins in the output shafts...you're ready to screw the T-case together.
Next up was to build the transmission...a super-simple 2-gear trans. Here's what it looks like on the inside, along with the two flange bearings in place on the motor mount (which is also the front half of the trans case, as the screws 'sealing' the trans go through the motor mount, and into the trans):
And, here's what it looks like attached to the motor mount, without the spur gear & slipper in-place:
With the trans attached to the motor mount, it was time to install the slipper & spur gear. In Ikaika's instructional videos, he says to add a 2mm & 1mm spacer...but, when I tried this, I discovered that the Nylock nut, even pressing extra-hard, couldn't reach the threads of the shaft. So, I removed the 1mm spacer. While still difficult to get the Nylock nut on, it was no longer impossible.
Finally, I attached the T-case to the skid, and attached the slave shaft between the trans & T-case. This was just to see how it looked (I did not thread lock the drive pin on the T-case side, as that will be done after installing the skid into the chassis)...and to test to make certain everything was rotating correctly, without resistance.
As for connecting the slave shaft & front/rear driveshafts, there were 3 possible ways, as the T-case has 4 output shafts - 2 on the front, and 2 on the rear. How one connects everything also plays into what axle gear sets are used (ie. the same front & rear, or OD on the front axle, or UD on the rear axle). The "standard" (Ikaika's) method gives the front axle a 30% OD. Option 2 (slave shaft to the front-right, front & rear driveshafts to both left outputs) provides a 30% reduction, from slave shaft to front/rear driveshafts. With options 2 & 3, an OD axle gear set is needed in the front axle and/or a UD gear set in the rear. Technically, there is a fourth possibility, but a person would have to be an idiot (ie. the rear ends up with 30% OD over the front). In the end, I opted for go with Ikaika's recommendation (option 1).
So far, I'm extremely happy with the GC 4.2. That's all for Part 1...Part 2 to (hopefully) follow shortly.
~ More peace, love, and kindness would make the world a much better place
![303517c110a1a5d5fc65cdf5da7248a7.jpg](/forums/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20210418%2F303517c110a1a5d5fc65cdf5da7248a7.jpg&hash=e7cf3134c11640ffd476c97ea8b6ab3d)
![c1b7ad07d03fa78f76083d6bd41d72c3.jpg](/forums/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20210418%2Fc1b7ad07d03fa78f76083d6bd41d72c3.jpg&hash=3b57c73bce0c4ee2b3f966e62f337ba7)
![9f8a278d72260c42ae9890f5f964f82f.jpg](/forums/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20210418%2F9f8a278d72260c42ae9890f5f964f82f.jpg&hash=c16fe18907acc096f70543ed7549c62e)
![903407691b73e13f45a2535c0e836079.jpg](/forums/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20210418%2F903407691b73e13f45a2535c0e836079.jpg&hash=b43c68da9a6a1334d0ab590dfb8d0077)
![623233c53df2fe5050f013bfa829a987.jpg](/forums/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20210418%2F623233c53df2fe5050f013bfa829a987.jpg&hash=7fe2440c46535c930e963f8438e65403)
![23aee21eb11de9a94091b923e23dc955.jpg](/forums/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20210418%2F23aee21eb11de9a94091b923e23dc955.jpg&hash=23e80ecfcfd3bf197c51455e941d37d8)
![2839d679f77aada6c5241afacdb6c32e.jpg](/forums/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20210418%2F2839d679f77aada6c5241afacdb6c32e.jpg&hash=270e4ec16f4bbb78a2e4457744d3c948)
![d3c582cb3aa2738b09675615d32fa19d.jpg](/forums/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20210418%2Fd3c582cb3aa2738b09675615d32fa19d.jpg&hash=78cf455ca694fb8cf057ecb5529d0f31)
![c28e11fd24ecb1903ea0ded4e0293d33.jpg](/forums/proxy.php?image=https%3A%2F%2Fuploads.tapatalk-cdn.com%2F20210418%2Fc28e11fd24ecb1903ea0ded4e0293d33.jpg&hash=f21d3686542bfa26296aaa40f74cbc6e)
