Ecto 4 Link conversion?
redneckwraith
HOOPER
Has anyone swapped out the trailing arm setup on their Ecto for triangulated 4 Link? If so which links did you use for the swap?
You should be able to use the knightrunner rear links, but your shocks will be laid over pretty far if you try using the gk shock hoops.
