heyok
This is for use when you have a set of receiver powered lights that you want to turn on and off, and a higher voltage light (maybe a light bar that runs at 12 volts) that you also want to be able to control. As a bonus, you can set the brightness of the higher voltage light.
A three position channel is used to operate this light controller. Normally keep the channel in the center. Push one way to toggle the receiver powered light on and off. Push the other way to set the brightness of the external powered output.
Watch a video of it working here:
RC Dual Output, Dual Powered Switch + Dimmer - YouTube
The components that do the switching are able to pass more than 10 amps of current each if they were properly heat sinked. That really isn't practical for RC because you don't really need that kind of power for lighting and also you probably don't want to be driving around with a heavy heat sink! In reality, it is probably safe to run 3 to 5 amps on each output. Again, these power levels are not likely anything you would ever need.
Part Number: RCSW2DPD
$34
$34
