I recently got a SCX10.II to swap my G6 body over to. I got the SSD Heavy Brass Knuckles for the front, but couldn't find any rear axle weights to suit me, so I decided to try and make some.
I ordered a set of these off ebay (slow boat from China took about 6 weeks). 64g each
Made a bracket out of .025" aluminum sheet.
Used a dremel to cut out the center out of 2 of the weight so it would slip over the end of the axle.
The other 2, I mounted to an old axle end and chucked it up in the drill press and used a bastard file to shave the outer diameter down to match the smaller portion.
After they were shaved down, I cut the centers out to match the first 2.
Then used M3x20 screws to bolt the bracket and both weights together to make a "1-ton brake drum" looking weight.
I had to shave down one flat of the M3 nuts, and sand flats on both sides of the axle so the weight would slip over the end of the axle.
I sprayed them with self etching primer and let them dry 24hr. Then painted them flat black. Curious to see how well the paint holds up on them though.
The finished weights come in at 125g per side, and worked out like I'd hoped they would.
