Speedtospare
This uses 2 sized of aluminum u channel to make and is painted rattle can black. The lights are wired for 11.1V. The 2 outter led's are standard bright led's but the inside are six 3 chip 5050 SMD led's. The setup is freaky bright. I also have two 9 led flashlights converted for headlights. I am waiting on some 47 ohm resistors to get the headlights at full brightness. It literally will light up a dark room. The entire light bar can be submerged in water.
Is this 100% scale? Probably not but it does resemble the new LED off-road light bars.
The bar is just placed on the top of the truck. I will tap the holes and bolt it down tonight. I lit up pictures is just resting on top of a 3S lipo. The truck is used for mainly trail running and some scale crawling. We have night runs so this should light up the trail a little better
tried taking some pics
