Dingo
Chodey24
Longview
If I put a 17.5t brushless motor in a dingo And bought 2.2 iroks. Would it crawl good and go good If I cut the body and
Made them fit??? Or is it better to keep 1.9s??
Iroks are decent for crawling and 2.2 should be fine. Does it rub when you flex out would be the question for cutting into the fenders?
As for if it will crawl good that depends on the rest of your set up. Post some pics of your rig under the body. Are you running aluminum links and steering as well as knuckles? What kind of servo? What about esc? Do you have softer springs or stock? Have you mirrored your tRansmssion? What foam set up are you running in the tires? What is the weight balance from front to back? Do you have weight in your knuckles or in your wheels? I would investigate those things in setting up your rig plus there is more but those are a good start.
