#deuceswildfoams - Heavy Weight Tuning Disc Set - Now Available
Nova's Ark
Tire&Foam Extraordinaire
Subscribed Member
C.I. Compound, Tyler, Texas
Crawler Innovations is out with another first. Introducing our Heavy Weight single stage closed cell tuning disc's. This new product is cut from the same material as our dense car stand foam. This dense tuning disc provides increased steering response, and adds width to the foam for wider tires. These foams are 100% water proof.
The Deuce's Wild Heavy Weight Tuning Disc set consists of four closed cell foam discs. These discs are designed to add width to your foams inside the tire. Generally it is recommended to install one disc on the outside of all four foams inside the tires. The discs do not fold over under load whether it's high speed, heavy weight, or simply turning. The discs can easily be trimmed with scissors to reduce the O.D. or increase the I.D.
Approximate size: 4.50" O.D. x 2.125" I.D. x .250" Thickness
#crawlerinnovations #activatedoutlaw #ayalametalworks #deuceswildfoams #rccrawler
Price is $16.95 set of four
P/N: CWR-3315
Available here:
RC Crawler Foams, Rock Crawler Foams, Tires and More by Crawler Innovations
