#deuceswildfoams - 3.8" Heavy Weight Foams - Now Available
Nova's Ark
Tire&Foam Extraordinaire
Subscribed Member
C.I. Compound, Tyler, Texas
Crawler Innovations was the first to combine closed cell and open cell foam into one package with our Double Deuce and Lil’ Nova product lines. After we'd perfected those systems, we turned our attention towards the faster paced rock racer, heavy scalers, and basher genres. The Deuce's Wild Foam line was created. Using only the firm inner material, while focusing on the machined size and shape of the foam.
CWR-3309 was designed for use in the Pitbull Tires 3.8 Rock Beast Tire (PB9009ZDK) but will fit many other brands of tires as long as they are similar in height and width. Examples are the Axial Racing BFG Krawler, Axial Racing Falken Wild Peak and the RC4WD Mud Slinger.
The Heavy Weight foams are solid firm foam that are machined to size. These foams do not currently compare to anything available on the RC market. The Heavy Weight foams do not fold over under load whether it's high speed, heavy weight, or simply turning. These foams rely on a small air gap between the foam and tire. This loose area allows for the tire to obtain traction, while the foam supports the tire. These foams help to the control the tire at full speed to reduce the pizza cutter effect on high speed brushless RC's. In certain high power applications, these foams will support the tire to drift across a loose surface. With these foams you will experience a new level of traction.
Approximate size: 6.625" Height x 2.625" Width (Remember that foam goes inside the tire and one must subtract lug and carcass thickness, plus any reinforcing from the overall tire height.)
#deuceswildfoams #activatedoutlaw #crawlerinnovations #ayalametalworks
Price is $29.95 pair (2)
P/N: CWR-3309
Available here:
RC Crawler Foams, Rock Crawler Foams, Tires and More by Crawler Innovations
