First i'm apologizing for my bad english. I hope all users understand me , i give my best...
I build a Berg in the end of 2012:
I startet with this Parts:
2x Egressor Motors 45T
1x Novak M2 DIG ESC
1x Hitec 7950 TH Servo
Super 300 CVD's
Titan Links
Felsefest Lenkung
10A BEC Castle
DCX3R Funke
Now:
2x Holmes Puller 13T
2x Sindewinder Micro
1x Sanwa MT4
1x Castle BEC
1x Futaba Servo 173 BLS
Super 300
Titan Links
Felsenfest Chassis
I changed the chassis from T1E to Stonecrasher MM3.1 and i get new Axle Tubes by customized.
https://picload.org/thumbnail/rglcpipi/2.jpg
This was a good first setup.
The panel color was not a eyecatcher, i changed it:
Next Step, i want to get down with the weight.
- Titan links
- Titan steering links
- lightwight gear set
On Christmas i get new rubbers, Voodoo.....
A good buddy did narrowed the Voodoos on a good dimention.
I change the size of the foams the narrowed tire.
after this it looks beautifull:
Now i enlarged the Rover and Boss Claws Tire to 148mm.
New Funke:
The permormance was really good.
But its time to make changes...
I installed a Felsenfest Chassis.
New panels:
New Tubes from RC Bros are installed.
First only on front. I need a longer shaft in the rear.
To come down with weight i change the reas links from Titan to Arrow Shafts in 7075 Alu.
But this was not enought, the money must burn
I see the gear case from Dlux and i was in love....
I must have this beautifull things....
Says and done:
intermediatedly i order Holmes Puller 13T.
This is the best motor i think, great performance!!!
4x enlarged Rovers:
And the success following:
Old rear axle and new:
Old:
New
First repair on the Berg:
The Arrow Links survived 2 Falls from 6m down.
After this, the material was sick and brocke later.
On the same time i get a brocken gear:
After this, i installed new rea links from Titan Tube
Thanks Eri!
Success is follwing....
From this time, i make only little changes.
I switch back to lower tires, Boss Claws and normal rover tires.
This year i was again under the best 3 in Germay
Videos:
https://youtu.be/3b5Mqo_BVxA
https://youtu.be/nFe4H5edKJY
https://youtu.be/8n0keRkyHC0
1x Novak M2 DIG ESC
Super 300 CVD's
Titan Links
Felsefest Lenkung
10A BEC Castle
DCX3R Funke
Now:
1x Sanwa MT4
1x Castle BEC
Super 300
Titan Links
Felsenfest Chassis
- Titan links
New Funke:
New panels:
Says and done:
4x enlarged Rovers:
Old:
New
Thanks Eri!
Videos:
