Its here!!! I'm exited to start putting it together tonight
I need a bigger table stat!
I've been wondering what a 560 sized motor looks like, next to a holmes sealed can 550 motor the Cross Rc motor is 8mm longer. I'm thinking a nice 550 motor might even out perform this simple sealed can motor. I like the idea that it can most likely be upgraded as I was afraid the 560 size would rule that out. Oh and the tranny comes assembled, I'll do a tear down to ensure all is good though.
Its a nice touch to include some tools besides the usual L (allen) wrenches
For a sense of scale next to a proline SR5 SCX10ii and a Gmade Gom
Oh and look at this ultra compact sound system, My god the size of this is just hilarious.
The tires felt pretty good a bit on the hard side but sticky (they remind me of the rubber from bike tires actually). I'll soak them in simple green to soften them up a bit more. the steel wheels are damn heavy though there are 8 of them so there's that.
I noticed there are some extra parts included at a quick glance, there are two different types of doors to choose from. they also included the plastic suspension components as well as the metal ones. But im not sure what purpose those plastic parts will play since the standard version thats meant to use them has seemingly been pulled off of their site, spare parts I guess.
First they start you off building the "shocks" which have an internal spring.
I believe they were 73mm eye to eye
They feel decent for an internally sprung shock the o-rings do an ok job of dampening the spring. Theres no chance of assembling this with oil it just wouldn't work.
Then on to the Trailer hitch and I can see this is going to be one of those builds where they have you jumping around a bunch
This thing is damn heavy weighing in at 12.7oz, I'll likely be making a styrene bed or something for the rear so I'm probably not going to use the hitch.
Mounting the tires is next but I'm skipping that since I'm currently soaking them in simple green to soften them up and clean up the mold release agent
Heres the tranny opened up, it was greased well
Its pretty massive and the layout is a bit different, theres no large spur gear. the 2 speed sort of dog box interface looks good
It has an inspection cover for checking gear mesh though you cant access the bolts that mount the motor to adjust from here which is unfortunate, it will take some trial and error/assembly and disassembly.
To check that all is well with the tranny they recommend connecting your (7.4v-11.1v) battery directly up to the motor so you can listen for anything wrong. Seriously WTF :roll: thats a terrible idea, you can simply stick a hex driver or something skinny though the output shaft and spin it by hand, or use two AA batteries.
On to the diffs and transfer cases.
The spool and diff gear are all one piece which is nice. I was expecting sintered metal but it looks like it might be something else I'm not entirely certain what, maybe cast with some machining.
some of the parts, it uses lots of C and E clips, bit of a bummer
assembled, they spin freely after I got all off the bearings seated. They mention not to use a bearing on one side of the input gear on the transfer case, not sure why, I used one but might need to round up a few more bearings later on im guessing.
the left side suspension arm assemblies
So far Im pretty pleased, though I'd be happier if there were less C & E clips used. Theres one page mostly in Chinese that lists batteries and voltage, it shows 11.1 volt Nmhi & Nicd or 7.4v Lipo. I'd like to be on 3S ideally but I might be pushing my luck possibly. 12.4v isn't too far off of 11.1v but its probably the snappyness of the lipo that's the issue.
Lots of heavy metal parts in this kit. Their tools are working nicely they have a good tight fit. Hardware has seemed good so far, all hex. Instructions are not the best but they work,
Notice how they call for using wire cutters to hold the shock shaft, odd and I tried to use my shock shaft pliers but it was proving too hard to compress the spring while grabbing the shaft with the pliers so I resorted to their method which was fine but sounds a bit crazy.
they've amended the standard version manual to include the parts for the flagship version with stickers showing different part numbers and half pages glued in to show the correct steps
