drewpyfz6
My question is: What is the best shock angle for crawling?
I have a rig that has 4 position holes at each end of the shock mounting.
Currently it is set at the lowest point on each, this gives the shock a very high angle, almost upright. And this lifts the chassis upwards.
If I was to go to the extreme the other way, then the shocks would be around 45 degrees "/" and the chassis would be closer to the ground.
It handles ok as it is, but looks a little tall - the weight is still low down, so has not fallen over - yet.
Looking at my other crawler, an AX10, these shocks are just at the 45degree angle and cant be changed that much (as standard).
Anyway just wanted to see if anyone knew if there was an advantage of either shock angle.
Cheers,
Drew
Cheers,
Drew
