![LJBQzJhh.jpg](/forums/proxy.php?image=https%3A%2F%2Fi.imgur.com%2FLJBQzJhh.jpg&hash=b8ccf33297ed47365ce5b1aef342155c)
TRX-4M Defender
This is my first journey into micro rigs as I was fascinated by the capability of the TRX-4M as I'm familiar with the Traxxas' house design. Coming from the TRX-4 Sport TRAXX project that I've been working on previous, I've decided to jump into a capable crawler out of the Defender despite is rear weight bias.
PSA: The Defender comes standard with the following spring rate setup:
Fronts: 0.072 Rate [TRA9757]
Rears: 0.155 Rate [TRA9760]
I feel as though that this isn't common knowledge and should be something people should be aware of when deciding on purchasing springs, esp for the rears. The Bronco comes with 0.095 Rate [TRA9758] on all four corners from the factory.
Anyways, I've done the following upgrades and this Defender is a crawling beast. I will get a scale to corner-balance the rig when I get the time, but stock weight distribution ratio was around 48:52 (F/R).
Electronics
- Traxxas Pro Scale LED Lights [TRA9784]
- LED Foglights (Orange)
- Injora LED Light Bar
- REEFS RC 99 Micro Servo x DSM Off Road TRX-4M Servo Mount
- REEFS RC SHORTY Micro Horn
Body
- Injora Roof Net with Accessories
- Spare Tire (Rear)
- Injora Tow Hooks (Front + Rear)
- Traxxas Lower Links (Steel) [TRA9749]
- Traxxas Hardware kit (Stainless Steel) [TRA9746X]
- Traxxas Steel Hollow Balls (Machined) [TRA7028X]
- Injora High Clearance Stainless Steel Links
Internals
- Injora Sealed Steel Bearings
Suspension
- Traxxas Shock Lower Retainer (Brass) - [TRA9761A] [On Backorder]
- Traxxas Shocks w/30wt OEM Shock Oil Mix
- Traxxas Springs - 0.125 Front [TRA9758] + 1 Clip / 0.155 Rear [Stock] (w/2x Preload Clips)
- Traxxas Steering Blocks, Brass [TRA9737]
- Traxxas Caster Blocks (Brass) [TRA9733]
- Injora Steering Link (Brass)
Powertrain
- Traxxas 7mm Wheel Hubs (Brass) [TRA9750X]
- Traxxas Driveshafts (6061-T6 Aluminum) Front / Rear [TRA9751-Gray]
- Traxxas Axle Shafts + Stub Axles (Hardened Steel) [TRA9756]
- Traxxas Metal Axle Gears [TRA9779]
- Traxxas Low Range Transmission Gear Set [TRA9776R]
- Traxxas Axle Covers, Brass (Front + Rear) [TRA9787]
- Injora 6mm Wheel Hub Extenders (Brass)
- Injora 24T/12T Alloy Steel Helical Gear Set [On Order]
- Treal Brass Extended Wheel Hubs 7mm*10mm Hex, Axle Counter Weight 17g/pc (4pcs) Wheel Spacer [On Order]
Wheels & Tires
- Traxxas Mickey Thompson Baja Pro X Tires [TRA9782]
- Traxxas Method 105 Beadlock Wheels [TRA9781]
- Traxxas Wheel Weights (Brass) Front and Rear [TRA9780]
- FubberStufferz V23 TRX SlymeBallz
Misc
- Jim's Bearings PTFE Coating for Axles Shafts, Stub Axles, Stub Axles, Transmission and Driveshafts
- Jim's Bearings Waterproof Grease for the Axle Gears and Transmission Gears
