The giveaway winner will be chosen by a random number generator on October 30th. To enter this giveaway you must be a member here on RCC. Crawler Innovations recommends that you become a star holding member and help support this forum which is a repository for rc crawling information. If you need information about becoming a star holding member, click this link.
Thank you for entering and good luck"thumbsup".
Rules to enter; Post one time, per day until October 30th.
Crawler Innovations is giving away a bolt on electronics tray for the front of the Axial Wraith. The tray is cut from 1/16th black delrin. It has counter sunk mount holes for use with the included 3mm hardware. This product is made in the U.S.A.
Please note, that if you are using the stock Axial Wraith Interior, you will need to modify it. You can do it several ways, 1. cut the interior to fit the tray, 2. heat the interior so that you can bend the interior out of the way, or 3. slot the interior so the tray to slides into it. Personally, I just cut mine to just below the dash. It's clean, simple, and gives plenty of room for under hood electronics.
Available @;
www.crawlerinnovations.com
Available @;
