Fishmaxx
There are several "RULE MYTHS" I continue to run across every time I go outside my local club.
I got 3 tires through!
If you only get 3 tires through its a penalty!
1.5 - Gate Marker (10 pts each): each gate will be comprised of 2 gate markers. Points are given when 4 wheels do not travel between gate markers or any part of the vehicle or driver touches a gate marker.
You can get 2x tires (1x front/1x rear same side) through for progress, but its penalty. 3x tires through means nothing special.
1.10 - Progress bonus (-2 progress point): shall be awarded to drivers for each gate that is cleared by the vehicle during the attempt of a course. A gate is considered cleared and a progress bonus shall be given when at least one front and one rear tire passes completely through the gate in the intended direction of the gate. All 4 tires must pass completely through the gate to receive the progress bonus without a gate penalty. (See Illustration A) A 10 point gate penalty shall be given if all 4 tires do not clear the gate, even if no gate marker is touched or straddled. The tires of the vehicle must travel completely through the gate, and not just break the plane of the gate. Tires must pass through the gate in the same direction and in the same attempt before a progress bonus is awarded.
Another myth thats related to this.
Driver driving through a gate claims....
I got progress before my tire hit the gate.
IMPOSSIBLE unless they go through the gate then reverse or back flip towards the gate. (See above)
I got PROGRESS because my wheel nut past the center of marker, so thats PROGRESS
WRONG see above
There are imaginary beams of light coming from the gate going straight up into the sky that you can't break
1000% WRONG There is zero reference to this being a rule. If anyone tells you that...."Tell that is not in the Rules!"
The ultra-simple break down is..
If you touch the gate, or don't get 4x Tires through the gate BEFORE making progress.....ITS A PENALTY
WRONG see above
