StomperCrawler
I just picked up 3 of these $3.89 (shipped, 99.9%+ feedback in 6k+ items seller) on eBay and won't see them for a while but I thought maybe others would like to try them (or have tried them) and chime in regarding their experience:"This unit features 5 pole construction for higher torque and power efficiency, anisotropic magnets, and coil specs of 55 turns of 32mm wire."
Motor Data:
Motor Data:
- Manufacturer: Mabuchi
- Model Number: RS-555PH-3225
- Speed@rated Torque: 3950 RPM
- Voltage: 9 to 30 VDC
- Nominal Voltage: 12VDC constant
- Motor Size: 1-7/16" (36.5mm) dia x 2-5/8" (66.7mm) long
- Shaft Size: 1/4 flatted shaft 1/8” (3.175mm) Diameter 1/2" (12.7mm) long
- Motor Connection: 3/16" (4.76mm) push on terminals
- No load speed: 5500RPM
- Torque@Rated Speed: 380.3 gm-cm
- Stall Torque: 1360 gm-cm
- Features: "wrap around" magnetic shield, 3mm mounting holes on the face
