Chassis help
crawler2.2
United States
I have the scx10.2 with the trans/transfer case. I'm looking for an LCG chassis that will allow this combo to be used and bolt up. Does anyone make a chassis for this setup or am I stuck with the standard 3 gear?
You might want to check out Rock Pirate RC for a flat skid option. Not sure how that transmission would work with an angled skid. Maybe someone else will chime in.
EDIT: Wait that shows the VRD transmission and the Axial 3-gear. Not sure about the SCX10 II transmission. You should try emailing them.
Rock Pirates Interceptor looks like what you want.
The Toyzuki V2 was made to use some of those transmission parts. Its an older design (~2018) but it was good. I dont remember if it uses stock length links or what though. Finding instructions for the build may not be easy now either. I'd think that Rock Pirates chassis would work but might take some fab work.
