Damion10
So after finishing my 10.3 build, I had the dreaded transmission click, partly due to one gear put on with the pin in the square hole but after fixing that I still had a very faint click when the rig was under a load. ( quiet on flat level surfaces )
After watching and reading everything I could find about this click it was deemed that the source comes from the transmission output gears ( behind the spur gear ) having some play between the gear and the shaft it rides on. While it technically won't hurt anything, I can't stand a $600 brand new rig having an annoying click.
One fix I found was putting a small amount of painters tape at the base of the shaft and on the pin which would help hold the gear tight. Well anyone who's tried to stick tape to anything thats had grease or oil on it you know its impossible, no matter how well its been cleaned.
Another fix I found was wrapping the shaft in aluminum foil acting as a shim between the gear and shaft. This seemed the best solution as the foil would just wedge and not have to stick. After finally getting the foil to stay between the shaft / gear initial tests were great. NO more click. perfect.
Fast foward to today, go out for a little run and guess what's back..... so after tearing the transmission apart again, I found the foil had worn down enough that the gear would move on the shaft again. Back to the drawing board....
After looking at how things were made, I noticed the gear on the shaft that runs the length of the transmission ( small gear ) didn't sit on top of the gear behind it ( one with the E clip holding it ) but rather sat on the pin and there was a small gap between the two.
So I found a small washer that fit perfectly between the E clip and bottom of the pin, installed the pin then the gear. No more play in the gear!!!! the washer forces the gear to sit true on the shaft while the pin locks it in.
After a quick test run its quiet and because the washer can't wear down like the tape / foil it should be a permanent fix.
Sorry this is so long I just wanted to post my findings in hopes it helps someone chasing this click as well.
