Badcopyinc
I searched for a while on this subject. and all i turn up is wiring diagrams.
I took two 3s 500mah lipos apart and made three 2s lipos and want to wire them all together parallel.
I wired each set with a 2s balance plug because i have a bad habit of never charging without it pluged in on my b6 charger.
My only concern is how to charge these because i would like to solder all three together in parallel to a deans connector. Im just not sure if it will charge just two cells through balance while having the deans plugged in?
am i forced to keep the main leads separated and make a y harness for when im using them in my crawler?
