Hey yall, ive done some searchin n come up with zilch on my problem.
Im having issues with a mamba x esc. I thought it was the motor, but ive swapped it n still had the same issue. When i try to go fwd or rev, i can hear the esc arm for just a second n it goes silent. The light is lit up green but i cant hear the "whine" from the motor. If i play with the throttle back n forth a bit it finally decides itll move. I had a HH trailmaster 2700kv in the rig. I got it used so i thought maybe it was the motor, which was a bit dirty when i took it apart. I put my CC slate 2850kv motor in, which i know is good, n still had the same effect. So i tryed another mamba x i had layin here n it works fine now.
The mamba x im having issues with i bought used a yr ago, but it just recently started acting up. I even checked to make sure it was up to date on firmware, checked the settings, to no avail. So my question is, is there a fix for this problem or do i need to get a new esc?
Any n all help is much appreciated!
